2 years later.....
So after 2 years standing I decided to get the fabia back on the road
So I fitted the 312mm/256mm big breaks to it and bled the system including clutch selecting gears is so much smoother than it was before took it down the road for a test run the pulling to the left that was present 2 years ago has improved 3 fold, so the hours I spent changing and checking things was all because of the breaks.
However stopping is not so good I read through very single post I can find but nothing with the issue I have.
Firstly applying the breaks was very stiff so I checked the vaccum and lines rectified a tiny split in the vaccum pipe and new jubilee clip on tandem pump this made things better bit something is not quite right
When I pump the pedal until hard and hold, start the car the pedal goes near on to the floor and I can't figure out why
I've bled it 3 times now old fashioned way and easy bleed
Can Anyone help it's driving me mad thanks
You need to bleed the ABS block as well using VCDS.
Can I use vcds lite or need the full version ? Thanks
I don't think lite works unfortunately (tried myself but no expert) i think iread you can register lite for $99 or something. Maybe that would work. Best bet would be to contact Rosstech
