Problem with amundsen
I tried to change background in my menu to carbon. I used instruction for golf and now my screen doesn't want to torn on. I changed coding back to previus set up but nothing happened. Screen backlight is on but screen is black or start up logo appears and stays on. Please help me. Link for instruction of codding
Anyone?
You've not given us much to go on.
What Amundsen unit is it? MIB1 - MIB2? What exactly did you do? Why did you use instructions for a VW rather than a Skoda unit? Did you randomly change coding to the settings in the Youtube video or were there relevant settings in the drop down box which you selected? Did you run a complete autoscan prior to making any changes? Did you save a log of that autoscan? Can you post the autoscan so that people can see more about what your problem might be?
Amundsen MIB1
Sorry for language but details are same.
Sobota,13,Lipiec,2019,23:52:40:00006
VCDS -- Emulator VAG/VAS pracuj¹cy w œrodowisku Windows, uruchomiony na Windows 8.1 x64
Wersja VCDS: AKP 17.8.1.0
Wersja danych: 20171214 DS276.6
www.vcds.pl
VIN: TMBBC7NE2F0244125   Numer rejestracyjny:
Typ podwozia: NE-SK37 (5Q0)
Skanowanie: 01 03 08 09 10 13 15 16 17 19 20 42 44 52 5F
VIN: TMBBC7NE2F0244125   Przebieg: 34515km
01-Silnik -- Stan: OK 0000
03-ABS/hamulce -- Stan: OK 0000
08-Klimatyzacja -- Stan: OK 0000
09-Centr.zesp.elektr. -- Stan: OK 0000
10-Asyst.park./kierow. -- Stan: OK 0000
13-Reg.dystansu -- Stan: OK 0000
15-Airbag -- Stan: OK 0000
16-Ko³o kierownicy -- Stan: OK 0000
17-Zest.wskaŸników -- Stan: OK 0000
19-CAN Gateway -- Stan: OK 0000
20-Asyst.œw.drogowych -- Stan: OK 0000
42-Elektr.drzwi kier. -- Stan: OK 0000
44-Wsp.kierownicy -- Stan: OK 0000
52-Elektr.drzwi pas. -- Stan: OK 0000
5F-Elektr.informacji -- Stan: OK 0000
Adres 01: Silnik (J623-CHPA)       Plik etykiet:. 04E-907-309-V1.clb
   Oznaczenie elementu SW: 04E 906 016 F    HW: 04E 907 309 A
   Komponent: 1,4l R4 TSI   H11 7861
   Weryfikacja: WAH11---
   Kodowanie: 01190032234401080000
   Kod serwisu: WSC 73430 031 00126
   Zbiór danych ASAM: EV_ECM14TFS01104E906016F 002011
   ROD: EV_ECM14TFS01104E906016F.rod
   VCID: 2541479624E1006EC2-8070
Nie znaleziono b³êdów.
Kody gotowoœci: 0000 0000
Adres 03: ABS/hamulce (J104)       Plik etykiet:. 5Q0-907-379-ESP-V1.clb
   Oznaczenie elementu SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Komponent: ESC           H32 0385
   Weryfikacja: 00000000    Numer seryjny: 61125000000360
   Kodowanie: 1A078A91242429700078060241C8245851249400608224F21423F072C002
   Kod serwisu: WSC 73430 031 00063
   Zbiór danych ASAM: EV_Brake1UDSContiMK100ESP 034033
   ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
   VCID: 479DED1EFEADF27E10-8012
Adres 08: Klimatyzacja (J255)       Plik etykiet:| 5G0-907-044.clb
   Oznaczenie elementu SW: 5E0 907 044 K    HW: 5E0 907 044 K
   Komponent: Climatronic   H03 0907
   Weryfikacja: 00001K06
   Kodowanie: 01110004100100011005004000101000
   Zbiór danych ASAM: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_VW37.rod
   VCID: 2D51BFB67C11382E0A-8078
   Sterownik dmuchawy œwie¿ego powietrza (z przodu):
   Czujnik ciœnienia i temperatury œrodka ch³odniczego:
   Czujnik jakoœci powietrza:
Adres 09: Centr.zesp.elektr. (J519)       Plik etykiet:| 5Q0-937-08X-HV1.clb
   Oznaczenie elementu SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Komponent: BCM MQBAB H   H18 0137
   Numer seryjny: 01011511300694
   Kodowanie: 0F000942424702FB07A04082B10C07280000000000000000000000000000
   Kod serwisu: WSC 73430 790 00126
   Zbiór danych ASAM: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 000F36029B03054691-8054
   Sterownik silnika wycieraczek:
   Podsystem 1 - Oznaczenie elementu SW: 5E2 955 119     HW: 5E2 955 119   Plik etykiet: 5QX-955-119-V1.CLB
   Komponent: WWS371 150412  041 0570
   Numer seryjny:         150417140118
   Kodowanie: 075DDD
   Czujnik rozpoznawania deszczu i œwiat³a:
   Podsystem 2 - Oznaczenie elementu SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Plik etykiet: 5Q0-955-547.CLB
   Komponent: RLHS  037 0059
   Numer seryjny: S3Y15M04D30H01M22S30
   Kodowanie: 00885D
   Czujnik uk³adu alarmowego:
   Podsystem 3 - Oznaczenie elementu SW: 5Q0 951 171     HW: 5Q0 951 171
   Komponent: Sensor, DWA  005 0315
   Numer seryjny: 000000000ZY1505101VE
   Syrena uk³adu alarmowego:
   Podsystem 4 - Oznaczenie elementu SW: 5Q0 951 605     HW: 5Q0 951 605
   Komponent: Sirene, DWA  004 0311
   Numer seryjny: 00000000000062180065
Adres 10: Asyst.park./kierow. (J791)       Plik etykiet:| 5Q0-919-298.clb
   Oznaczenie elementu SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Komponent: PARKHILFE PLA H12 0047
   Weryfikacja: --------    Numer seryjny: 39431510101464
   Kodowanie: 0131061041
   Kod serwisu: WSC 73430 790 00063
   Zbiór danych ASAM: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_SK37.rod
   VCID: 428BFC0AD58FD756C7-8016
Adres 13: Reg.dystansu (J428)       Plik etykiet:| 5Q0-907-572-V1.clb
   Oznaczenie elementu SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Komponent: ACC Bosch MQB H05 0304
   Numer seryjny: 26031503271521
   Kodowanie: 00000200FE0739
   Zbiór danych ASAM: EV_ACCMRRBoschVW372 001015
   ROD: EV_ACCMRRBoschVW372_VW26.rod
   VCID: 387F9EE283538D8669-806C
Adres 15: Airbag (J234)       Plik etykiet:| 5Q0-959-655.clb
   Oznaczenie elementu SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Komponent: Airbag VW20   012 0200
   Weryfikacja: --------    Numer seryjny: 003P4P7NV4F8
   Kodowanie: 98CCC000000000005C5400CC008800000065
   Zbiór danych ASAM: EV_AirbaVW20TS6VW48X 001116
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F0DB5FEE6FD7ABEE8-802A
   Czujnik zderzenia bocznej poduszki bezp.po stronie kierowcy:
   Podsystem 1 - Oznaczenie elementu SW: -----------    HW: 454 001 004 15
   Komponent: SideSensor_Df  008 0887
   Numer seryjny: 3576U0000009E8602419
   Kodowanie: 2D2D2D
   Czujnik zderzenia bocznej poduszki bezp.po stronie pasa¿era:
   Podsystem 2 - Oznaczenie elementu SW: -----------    HW: 454 000 804 15
   Komponent: SideSensor_Pf  008 0887
   Numer seryjny: 3586U0000003F5602412
   Kodowanie: 2D2D2D
   Czujnik zderzenia bocznej poduszki bezp.z ty³u po str.kierowcy:
   Podsystem 3 - Oznaczenie elementu SW: -----------    HW: 454 801 304 15
   Komponent: SideSensor_Dr  111 0148
   Numer seryjny: 3516R6B9A64060000008
   Kodowanie: 2D2D2D
   Czujnik zderz.bocznej poduszki bezp.z ty³u po str.przedn.pasa¿.:
   Podsystem 4 - Oznaczenie elementu SW: -----------    HW: 454 800 907 18
   Komponent: SideSensor_Pr  301 0148
   Numer seryjny: 3526R3BFA6815000000G
   Kodowanie: 2D2D2D
   Czujnik zderzenia przedniej poduszki bezp.po stronie kierowcy:
   Podsystem 5 - Oznaczenie elementu SW: -----------    HW: 454 802 403 15
   Komponent: FrontSensor_D  114 0149
   Numer seryjny: 3556V727A1C060000009
   Kodowanie: 2D2D2D
Adres 16: Ko³o kierownicy (J527)       Plik etykiet:| 5Q0-953-549.clb
   Oznaczenie elementu SW: 5Q0 953 507 DL    HW: 5Q0 953 549 C
   Komponent: Lenks. Modul  002 0110
   Weryfikacja: --------    Numer seryjny: 28041508490433
   Kodowanie: 6C00
   Zbiór danych ASAM: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_009_AU37.rod
   VCID: 0305390E8A151E5E8C-8056
Adres 17: Zest.wskaŸników (J285)       Plik etykiet:| 5G0-920-XXX-17.clb
   Oznaczenie elementu SW: 5E0 920 950     HW: 5E0 920 950
   Komponent: KOMBI         310 4270
   Kodowanie: 27A502002590A60001886A011000000000000000
   Zbiór danych ASAM: EV_DashBoardVDDMQBAB 009037
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 63C5198E6A55BE5EEC-8036
Adres 19: CAN Gateway (J533)       Plik etykiet:| 5Q0-907-530-V1.clb
   Oznaczenie elementu SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Komponent: GW MQB High   128 1204
   Weryfikacja: --------    Numer seryjny: 0003403252
   Kodowanie: 030100042F085700FF000258080F00010001050000000000000000000000
   Zbiór danych ASAM: EV_GatewLear 011020
   ROD: EV_GatewLear_011.rod
   VCID: 72EB6CCAA5AF27D697-8026
   Alternator:
   Sterownik kierownicy wielofunkcyjnej:
   Podsystem 2 - Oznaczenie elementu SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Komponent: E221__MFL-PR6  H05 0130
   Numer seryjny: 000000000D0789200415
   Sterownik uk³adu kontroli akumulatora:
   Podsystem 3 - Oznaczenie elementu SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Komponent: J367-BDM  H08 0223
   Numer seryjny: 62104D28554291850544
Adres 20: Asyst.œw.drogowych (J844)       Plik etykiet:| 8X0-857-511.clb
   Oznaczenie elementu SW: 5G0 857 511 D    HW: 5G0 857 511
   Komponent: FLA           H04 0002
   Weryfikacja: AA001001
   Kodowanie: 01028F6B76765D525220343E01
   Zbiór danych ASAM: EV_HighBeamAssisAU37X 001009
   ROD: EV_HighBeamAssisAU37X.rod
   VCID: 2B55B1AE4205361E14-807E
Adres 42: Elektr.drzwi kier. (J386)       Plik etykiet:| 5QX-959-X93-42.clb
   Oznaczenie elementu SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Komponent: TSG FS        009 0015
   Numer seryjny: 0000147755801
   Kodowanie: 00150020D001040000001100
   Zbiór danych ASAM: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
   VCID: 4581E716C4A1E06EE2-8010
   Sterownik tylnych drzwi po stronie kierowcy:
   Podsystem 1 - Oznaczenie elementu SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Plik etykiet: 5QX-959-81X-V1.CLB
   Komponent: FOND_FHSG_DRV  005 0005
   Numer seryjny: 00000000000005913629
   Kodowanie: 1D0200
Adres 44: Wsp.kierownicy (J500)       Plik etykiet:| 5Q0-909-144.clb
   Oznaczenie elementu SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
   Komponent: EPS_MQB_ZFLS  125 1061
   Kodowanie: 8303
   Zbiór danych ASAM: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB.rod
   VCID: 4385F90ECA95DE5ECC-8016
Adres 52: Elektr.drzwi pas. (J387)       Plik etykiet:| 5QX-959-X92-52.clb
   Oznaczenie elementu SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Komponent: TSG BFS       009 0015
   Numer seryjny: 0000147199756
   Zbiór danych ASAM: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
   VCID: 4487FA12CF9BD966F5-8010
   Sterownik tylnych drzwi po stronie przedniego pasa¿era:
   Podsystem 1 - Oznaczenie elementu SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Plik etykiet: 5QX-959-81X-V1.CLB
   Komponent: FOND_FHSG_PSG  005 0005
   Numer seryjny: 00000000000005899909
   Kodowanie: 050200
Adres 5F: Elektr.informacji (J794)       Plik etykiet:| 5E0-035-MIB-STD1.clb
   Oznaczenie elementu SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Komponent: MU-S-ND-ER    041 0435
   Numer seryjny: S7F02804153163
   Kodowanie: 03730101FF0000001111120100A800002F0000860100010046
   Zbiór danych ASAM: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_AU37.rod
   VCID: 2643409A59E70B76CB-8072
   Jednost.wskazañ i obs³ugi 1 elektroniki uk³adów informacyjnych:
   Podsystem 1 - Oznaczenie elementu SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Komponent: ABT_Std_Nav  H60 0030
   Numer seryjny: SKZ8Z9RT301LUM
   Naklejka z danymi:
   Podsystem 2 - Oznaczenie elementu SW: 5E0 051 236     HW: -----------
   Komponent:  ECE 2018/201  --- 0075
   Numer seryjny: --------------------
Koniec --------------------(Skanowanie trwa³o: 03:40)----------------------
This one did today
Monday,22,July,2019,22:48:38:00006
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.2.0.3 (x64)
Data version: 20180212 DS287.0
www.Ross-Tech.com
VIN: TMBBC7NE2F0244125   License Plate:
Chassis Type: NE-SK37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 20 42 44 52 5F
VIN: TMBBC7NE2F0244125   Mileage: 34805km-21626miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 F    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   H11 7861
   Revision: WAH11---
   Coding: 01190032234401080000
   Shop #: WSC 73430 031 00126
   ASAM Dataset: EV_ECM14TFS01104E906016F 002011
   VCID: 2541479624E1006C4B-8070
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-ESP-V1.clb
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Component: ESC           H32 0385
   Revision: 00000000    Serial number: 61125000000360
   Coding: 1A078A91242429700078060241C8245851249400608224F21423F072C002
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033
   ROD: EV_Brake1UDSContiMK100ESP_034_VW37.rod
   VCID: 479DED1EFEADF27C99-8012
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5E0 907 044 K    HW: 5E0 907 044 K
   Component: Climatronic   H03 0907
   Revision: 00001K06
   Coding: 01110004000100011005004000101000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_003_SK37.rod
   VCID: 2D51BFB67C11382C83-8078
   Fresh Air Blower Front:
   Refrigerant Pressure And Temperature Sender:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011511300694
   Coding: 0F000942424702FB07A04082B10C07280000000000000000000000000000
   Shop #: WSC 73430 790 00126
   ASAM Dataset: EV_BCMCONTI 013000
   VCID: 000F36029B03054418-8054
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 150412  041 0570
   Serial number:         150417140118
   Coding: 074DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S3Y15M04D30H01M22S30
   Coding: 00885D
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Component: Sensor, DWA  005 0315
   Serial number: 000000000ZY1505101VE
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Component: Sirene, DWA  004 0311
   Serial number: 00000000000062180065
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 F    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0047
   Revision: --------    Serial number: 39431510101464
   Coding: 0131061041
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003019
   ROD: EV_EPHVA2CAU3700000_003_AU37.rod
   VCID: 428BFC0AD58FD7544E-8016
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 26031503271521
   Coding: 00000200FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001015
   VCID: 387F9EE283538D84E0-806C
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0200
   Revision: --------    Serial number: 003P4P7NV4F8
   Coding: 98CCC000000000005C5400CC008800000065
   ASAM Dataset: EV_AirbaVW20TS6VW48X 001116
   VCID: 7F0DB5FEE6FD7ABC61-802A
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 454 001 004 15
   Component: SideSensor_Df  008 0887
   Serial number: 3576U0000009E8602419
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 454 000 804 15
   Component: SideSensor_Pf  008 0887
   Serial number: 3586U0000003F5602412
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 454 801 304 15
   Component: SideSensor_Dr  111 0148
   Serial number: 3516R6B9A64060000008
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 454 800 907 18
   Component: SideSensor_Pr  301 0148
   Serial number: 3526R3BFA6815000000G
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 454 802 403 15
   Component: FrontSensor_D  114 0149
   Serial number: 3556V727A1C060000009
   Coding: 2D2D2D
Address 16: Steering wheel (J527)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 507 DL    HW: 5Q0 953 549 C
   Component: Lenks. Modul  002 0110
   Revision: --------    Serial number: 28041508490433
   Coding: 6C00
   ASAM Dataset: EV_SMLSKLOMQB 017001
   ROD: EV_SMLSKLOMQB_013_AU37.rod
   VCID: 0305390E8A151E5C05-8056
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5E0 920 950     HW: 5E0 920 950
   Component: KOMBI         310 4270
   Coding: 27A502002590A60001886A011000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009037
   ROD: EV_DashBoardVDDMQBAB_009_VW37.rod
   VCID: 63C5198E6A55BE5C65-8036
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AC    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1204
   Revision: --------    Serial number: 0003403252
   Coding: 030100042F085700FF000258080F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 011020
   ROD: EV_GatewLear_011_VW37.rod
   VCID: 72EB6CCAA5AF27D41E-8026
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H05 0130
   Serial number: 000000000D0789200415
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 F    HW: 5Q0 915 181 F
   Component: J367-BDM  H08 0223
   Serial number: 62104D28554291850544
Address 20: High Beam Assist. (J844)       Labels:| 8X0-857-511.clb
   Part No SW: 5G0 857 511 D    HW: 5G0 857 511
   Component: FLA           H04 0002
   Revision: AA001001
   Coding: 01028F6B76765D525220343E01
   ASAM Dataset: EV_HighBeamAssisAU37X 001009
   VCID: 2B55B1AE4205361C9D-807E
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000147755801
   Coding: 00150020D001040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 4581E716C4A1E06C6B-8010
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000005913629
   Coding: 1D0200
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 R    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 8303
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB_012_VW37.rod
   VCID: 4385F90ECA95DE5C45-8016
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000147199756
   ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 4487FA12CF9BD9647C-8010
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000005899909
   Coding: 050200
Address 5F: Information Electr. (J794)       Labels:| 5E0-035-MIB-STD1.clb
   Part No SW: 5E0 035 874 A    HW: 5E0 035 874 A
   Component: MU-S-ND-ER    041 0435
   Serial number: S7F02804153163
   Coding: 03730101FF0000001111120100A800002F0000860100010046
   ASAM Dataset: EV_MUStd4CPASE 002039
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 2643409A59E70B7442-8072
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5E0 919 605 D    HW: 5E0 919 605 D
   Component: ABT_Std_Nav  H60 0030
   Serial number: SKZ8Z9RT301LUM
   Data medium:
   Subsystem 2 - Part No SW: 5E0 051 236     HW: -----------
   Component:  ECE 2018/201  --- 0075
   Serial number: --------------------
End-------------------------(Elapsed Time: 03:45)--------------------------
Advanced Identification/FAZIT
     Identification: PM6-001
     Date: 28.04.15
     Manufacturer number: 0850
     Test stand number: 3163
Flash Status
     Programming Attempts(application): 0/0
     Programming Attempts(data): 65535/0/1
     Successful Attempts(data): 65535/0/1
     Flash Date: 00.01.01
     Flash Tool Code(data): 00063 031 73430
Misc.
     Hardware number: 5E0 035 874 A
     Workshop System Name: J794
     Equipment/PR Code: 00000000058E4211
     Dataset Number: 5E0CV1t____
     Dataset Version: 0049
     ASAM Dataset Revision: 002039
Car Info
     Chassis Number: TMBBC7NE2F0244125
VCDS Info:
       Labels: 5E0-035-MIB-STD1.clb
That is what i did.
Adres 5F,5E0 035 874 A,przekodowany (Kodowanie d³ugie),z,03730101FF0000001111120100A800002F0000860100010046,na,03730101FF0000001111120100A800002F0100860100010046,(73430/790/00063),Pi¹tek,19,Lipiec,2019,23:32:40:00006
Adres 5F,5E0 035 874 A,przekodowany (Kodowanie d³ugie),z,03730101FF0000001111120100A800002F0100860100010046,na,03730101FF0000001111120100A800002F0200860100010046,(73430/790/00063),Pi¹tek,19,Lipiec,2019,23:38:58:00006
Adres 5F,5E0 035 874 A,przekodowany (Kodowanie d³ugie),z,03730101FF0000001111120100A800002F0200860100010046,na,03730101FF0000001111120100A800002F0300860100010046,(73430/790/00063),Sobota,20,Lipiec,2019,06:24:58:00006
Adres 5F,5E0 035 874 A,przekodowany (Kodowanie d³ugie),z,03730101FF0000001111120100A800002F0300860100010046,na,03730101FF0000001111120100A800002F0000860100010046,(73430/790/00063),Sobota,20,Lipiec,2019,09:11:24:00006
So maybe anyone knows VAG specialist in Nottingham.
Is it possible to instal software without activating update option in radio menu? Service can't do it.
Problem solved. Screen is working. Thank you all for help
What did you do to solve it?
In case other people come across this thread with same problem.
https://xkcd.com/979/
