ASV problem!!Please help!!
Hello everyone.
I have a problem with my car, Skoda Octavia 2.0 TDI CR, 2011year.
MIL is on and the codes are P2111 and P2080.
The car is shuderring when I turn it off. Yesterday I swapped my ASV with another one with the same numbers (03L 128 063 R) but the car is still shuderring.
Does anybody know what the problem is? Are there any fuses that control the Work of the ASV and EGR?
Here is log from the VCDS.
VCDS Version: Release 12.12.0
Data version: 20130910
Monday,23,September,2019,21:20:29:62939
Chassis Type: 1Z (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: TMBBE21Z0B2134775
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Malfunction 0010
Address 01: Engine (J623-CFHC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 C    HW: 03L 906 018 BR
   Component: R4 2,0L EDC   H23 7100
   Revision: 42H23---    Serial number:
   Coding: 00190012040400080000
   Shop #: WSC 73430 031 00090
   ASAM Dataset: EV_ECM20TDI01103L906018C 003005
   ROD: EV_ECM20TDI01103L906018C.rod
   VCID: 2A5BE4234D0AF24EEA7-807F
2 Faults Found:
8187 - Exhaust Gas Temp Bank 1 Sensor 1 (G235)
          P2080 00 [237] - Implausible Signal
          MIL ON - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 199595 km
                    Date: 2000.00.00
                    Time: 00:00:00
9124 - Throttle Actuator Control System
          P2111 00 [109] - Stuck Open
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 170
                    Mileage: 202898 km
                    Date: 2093.14.25
                    Time: 16:18:51
Readiness: 1 2 0 0 0
Thank  you for your help!
