Octavia Scout 4Motion drivetrain compatibility
I'm looking for a little technical guidance on the Mk1 Octavia Scout 4WD drivetrain.
Essentially I am attempting to build a 4WD drivetrain for a non-4Motion Volkswagen car, using parts of a Mk4 Golf 4Motion. The idea was to use the 4Motion system coupled with a 1.9TDI variant engine but this is a problem in the UK as VW didn't bring over many 1.9 powered 4Motions and what is around seems to be lots of Golf 2.8V6 petrol 4Motions. I have already gutted a Golf for the floor, prop, gearbox and complete rear Haldex axle setup.
But the V6/V5 2WD gearbox has a different pattern then the 4 cylinder engines and the gear ratios may not easily be suited to a TDI.
So today i got to wondering if there was a Skoda equivalent of the Golf TDI 4Motion as this is probably a more readily available car. I was thinking the gearbox would be an 02M variant and by using the Golf propshaft, cradle etc with the box and matching diff for a 4 cylinder I could make a TDI 4Motion?
Does this make any sense?
Audi A3 TDi quattro would be a good place to start.
The only MKI Octavia 4x4 in the UK was petrol, that said it's a fairly straight forward swap with a TDI donor to make a TDI 4x4.
Thanks for that suggestion. I had totally overlooked the A3 and I could use the whole engine and drivetrain from a PD130 to upgrade the car as part of the conversion.
This project can now become a reality 👏
