Reasonably priced snow foam adapter
Hi Guys,
Bought a nilfisk c110 on prime day the other week. Finally used it last weekend.
Bought some PolarBlast snow foam to run through it and the included snow foam adapter and it didn't foam too well.
I understand the adapter has a big influence on this and so was thinking of getting another and using the included one with the polar sealer.
I'm looking for something that is good VFM. I don't want to spend a fortune but don't want to buy something that is marginally better than the included one.
Can £20-25 get something reasonable.?
I'd have a look on the in2detailing website. I'm sure the one for my Karcher was about £19.
I've been using polar blast through it with great results although I'll probably try bilt hamber next as now the novelty of shaving foam thickness has wore off I want something with a bit more cleaning power.
Use code DW10 or forensic for 10% off at the checkout as well. You'll need to select the correct fitting for your pressure washer as well.
After reading quite a bit, I now use mine (bilt hamber) in a £8.99 garden sprayer from Screwfix.  Doesn't foam but works really well.  On hot days I use the mist setting on a garden hose to stop it drying out.
Gaz
