Small speakers in the door
Hi, so when i turn left i hear a wierd fuzzy noise coming from the drivers side door.
I went ahead and took the door panel off and seen that the small speaker that sits next to the wing mirror controls had somehow fell down the panel and when i was turning left the small speaker was hitting the metal panel that the larger speaker is attached to which was causing the noise and occasionally stopping the larger speaker to stop working.
The small speaker also doesnt work but when i have searched the forum to see about replacing the speakers i can only see where people replace the larger 6" speakers. Can anyone please guide me on how i replace this or direct me where i could purchase a small speaker please.
You'd probably need to remove the whole door trim to be able to replace the speaker. Take a look here:
There doesn't seem to be enough room the replace it by simply removing the grid, shown at very beginning of the video.
Part no. is 1U0035411E.
Thank you, i did manage to remove the panel. Just this part is hard to find on the net 😞
Probably a genuine replacement part from a skoda dealer unless you can match to something very similar.
