Engine Plug Wires - 2013 Skoda Fabia - 1.6 Diesel CAYA Engine
Could anybody advise me on what & where the wires go on the engine plug, that is part of the engine loom, NOT the ECU Plug.
it has 14 pins - part number - 1J0 973 737
The Wires are as follows
Black / Blue
Red / Yellow
Brown / Green
Black / Yellow
Brown
Black / Red
Black / Blue
Brown
Black / green
Black / White
Brown / Purple
Blue / Red
White
Green / Black
Thank you....
                        Richard.
Repeated, as I had a wire mixed up in the Thank You Previously...
  • Sponsor
Pin 1 green/black wire from oil pressure switch destination Cluster pin27
Pin 2 white wire to ECU pin 94a/16 changes to yellow at 14-way rad outlet temp sensor pin 1
Pin 3 blue/red power to N276 and N290
pin 4 brn/vio from N75 to ecu pin T60a/20
pin 5 blk/grey  glowplug 4 to J179/4
pin 6 blk/green glowplug 3 to J179/3
pin 7 earth to oil level sensor and coolant circ pump 2
pin 8 blk/blu glowplug 2 to J179/2
pin 9 blk/red glowplug 1 to J179/1
pin 10 thinner brown radiator outlet temp sensor pin 2
pin 11 blk/yel power feed for oil level/temp sensor G266
pin 12 brown/green signal from G266 destination cluster pin 11
pin 13 red/yel changing to wht/red power to EGR N345 valve
pin 14 ECU pin  94a/47blu/blk changing to grn/blk EGR N345 valve
That was quite hard work, so please send me a large glass of red. Ta. :)
