GPS disactivated
Hi every one, I’m a new member, I’ve got my Kodiaq 2 weeks ago.
I am from Morocco; here Kodiaq comes with no GPS (I think it is deactivated). Any idea how to activate it?
What should I do, and how? Thanks in advance.
Hi, welcome to Briskoda B)
Which infotainment system do you have fitted to your Kodiaq?
Swing, Bolero, Amundsen or the Columbus?
When you say 'GPS' are you referring to what is commonly referred to as satellite navigation?
If you don't have sat nav currently, this would suggest you have either the Swing or the Bolero infotainment system fitted?
Bolero
yes i ment by GPS : satellite navigation system.
is there anything i can do to have it? (i'm useing Waze via Android Auto, but i don't like it) :-/
Waze is much more accurate than the in-built GPS. The Skoda sat nav systems do tend to get quite a lot of criticism.
I use Waze a lot, what is it you don't like about it?
I think the only way to get the inbuilt system will be to upgrade your infotainment system to Amundsen as a minimum...
Edited by silver1011
ok i see, thanks a lot.
Waze is much more accurate as you said   ( US $388.93 for Amundsen is too much also hhhh ).
