Phone option missing from maxidot
A few months back i could pair my phone to the columbus. But i deleted the paired phone from car, got new phone, and cannot pair phone. Also phone option missing from maxidot. When i push phone on columbus, only mutes the radio.
With vcds i cant access 77 phone, says control module wont answer. What do i have to do to be able to pair phone again?
I made a check. Codes:
Saturday,26,October,2019,12:43:49:00007
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 8.1 x64
VCDS Version: 18.9.0.2 (x64)
Data version: 20180927 DS296.0
www.Ross-Tech.com
VIN: TMBGT61Z4C2030469   License Plate:
Mileage: 153440km-95343mi   Repair Order:
Chassis Type: 1Z-SK35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 52 55 56 61 62 69
          72 77
VIN: TMBGT61Z4C2030469   Mileage: 153440km-95343miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 NF    HW: 03L 906 023 JH
   Component: 1,6l R4 CR td H43 9971
   Revision: --H43---    Serial number:
   Coding: 00114036032401080000
   Shop #: WSC 73430 031 00066
   ASAM Dataset: EV_ECM16TDI02103L906023NF 003009
   ROD: EV_ECM16TDI.rod
   VCID: 77FD5DDDCECD43F2E4-8022
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BJ    HW: 1K0 907 379 BJ
   Component: ESP MK60EC1   H31 0121
   Revision: 00H31001
   Coding: 113B201C092500FA880F04EA90220051350800
   Shop #: WSC 73430 790 00066
   VCID: 7BF541EDFAE5679280-802E
1 Fault Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 62
                    Reset counter: 234
                    Mileage: 123585 km
                    Time Indication: 0
                    Date: 2015.11.04
                    Time: 00:02:33
             Freeze Frame:
                    Count: 3
                    Count: 0
                    Count: 20992
                    Count: 397
                    Count: 43264
                    Count: 1
                    Count: 1278
                    Count: 0
Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
   Part No SW: 3T0 907 044 BK    HW: 3T0 907 044 BK
   Component: Climatronic   H18 0506
   Revision: 00001007
   Coding: 0000000003
   ASAM Dataset: EV_Climatronic A01010
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 7CF742F1F7EB60AA89-8028
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 Q    HW: 1K0 937 087 Q
   Component: BCM PQ35  H   110 0651
   Revision: 00110 AC
   Coding: 60000AB8E05BF1C440080080110011E443F000AE626D81605C85C7000041
   VCID: 3F8DF5FDAE7DBBB2EC-806A
   Subsystem 1 - Part No: 1Z1 955 119 D  Labels: 1KX-955-119.CLB
   Component: Wischer 30061  26  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
   Component: RLS 050711 05  54  0403
   Coding: 0730ED
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor 03   03 1209
   Subsystem 4 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HO  H11 9005
2 Faults Found:
02745 - Bulb for Daytime Running Light; Left
            010 - Open or Short to Plus
             Freeze Frame:
                    Fault Status: 01101010
                    Fault Priority: 2
                    Fault Frequency: 254
                    Reset counter: 195
                    Mileage: 148521 km
                    Time Indication: 0
                    Date: 2013.09.19
                    Time: 10:56:36
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
02746 - Bulb for Daytime Running Light; Right
             Freeze Frame:
                    Fault Priority: 2
                    Reset counter: 195
                    Mileage: 148521 km
                    Time Indication: 0
                    Date: 2013.09.19
                    Time: 10:56:36
             Freeze Frame:
                        Term 15 On
                    Voltage: 12.10 V
                        ON
                        ON
                        Term 50 On
                        OFF
                        OFF
Address 10: Park/Steer Assist (J446)       Labels:| 1Z0-919-475-V2.clb
   Part No SW: 1Z0 919 475 E    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0005
   Revision: --H06---    Serial number: 28291116781568
   Coding: 318001
   Shop #: WSC 27891 211 88589
   ASAM Dataset: EV_EPHVA18SKxxx0000 001001
   ROD: EV_EPHVA18SKxxx0000_001.rod
   VCID: 4385F90DCA95DF5288-8016
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: Q6 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PC2695UE
   Coding: 0020790
   VCID: 3D718FF56471A9A2FE-8068
   Subsystem 1 - Serial number: 6332MSME6055483BD
   Subsystem 2 - Serial number: 6342MSME60552621%
   Subsystem 3 - Serial number: 6351HSME28101C685
   Subsystem 4 - Serial number: 6361HSME28103368%
Address 16: Steering wheel (J527)       Labels:| 5K0-953-569.clb
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Component: LENKS.MODUL   014 0140
   Revision: FF010040    Serial number: 20110704200368
   Coding: 108A140000
   ASAM Dataset: EV_SMLSNGVOLWSXS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79F95BE5F8D9558292-802C
   Multifunction steering wheel control module:
   Subsystem 1 - Part No SW: 3T0 959 537     HW: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO  H07 0012
   Coding: 800000
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 1Z0 920 843 S    HW: 1Z0 920 843 S
   Component: KOMBI         H04 0607
   Serial number: 00000000000000
   Coding: 110C01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 489FEE21F3B3FC0A5D-801C
Address 19: CAN Gateway (J533)       Labels:. 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 J    HW: 1K0 907 951
   Component: J533  Gateway H43 1620
   Revision:   H43       Serial number: 010711F1001656
   Coding: 352302
   VCID: 377D9DDD864D83F224-8062
1 Fault Found:
01303 - Telephone Transceiver (R36)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 106
                    Mileage: 148903 km
                    Time Indication: 0
                    Date: 2013.09.27
                    Time: 13:08:53
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H04 0607
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB74A98D7FEE1A6B-803E
Address 37: Navigation (J0506)       Labels:. 1T0-035-680.clb
   Part No SW: 3T0 035 680 K    HW: 3T0 035 680 C
   Component: RNS-MID       H55 5238
   Revision: AB001001    Serial number: SKZ6Z7L2191028
   Coding: 04010042010000910000
   Shop #: WSC 73430 790 12345
   VCID: 387F9EE18B538C8A2D-806C
   Subsystem 1 - Part No: 3T0 051 859 AT
   Component: EU West V16  8536
4 Faults Found:
00859 - Line-Output; Front Right
            011 - Open Circuit
             Freeze Frame:
                    Fault Status: 01101011
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153440 km
                    Time Indication: 0
00869 - Line Output; Rear Right
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153440 km
                    Time Indication: 0
00860 - Line-Output; Rear Left
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153440 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153441 km
                    Time Indication: 0
                    Date: 2014.03.18
                    Time: 11:38:52
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2119
   Coding: 0136438
   VCID: 76E350D901C73AFAFF-8022
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 69     3201
   Revision: 00H20000
   VCID: 3467AAD1573B68EA01-8060
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0136438
   VCID: 489FEE213BB3FC0A5D-801C
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
            005 - No or Incorrect Basic Setting / Adaptation
Address 55: Headlight Range        Labels: 5M0-907-357-V2.lbl
   Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
   Component: AFS-Steuergeraet    0148
   Revision: 00H04000    Serial number:
   Coding: 1507354
   Subsystem 1 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0004
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0005
   Coding: 00000023
Address 56: Radio (J0506)       Labels:. 1T0-035-680.clb
4 Faults Found:
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153440 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153440 km
                    Time Indication: 0
            011 - Open Circuit
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153440 km
                    Time Indication: 0
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 195
                    Mileage: 153441 km
                    Time Indication: 0
                    Date: 2014.03.18
                    Time: 11:38:52
Address 61: Battery Regul. (J840)       Labels:. 1K0-907-534.clb
   Part No SW: 7N0 907 534     HW: 1K0 907 951
   Component: Batt.regelung H43 1620
   Coding: 030B185A
   VCID: 71E963C5A8A91DC22A-8024
   Subsystem 1 - Part No SW: 1K0 915 181 H    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900751260
1 Fault Found:
02256 - Quiescent Current
            001 - Upper Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00110001
                    Fault Priority: 7
                    Fault Frequency: 140
                    Reset counter: 234
                    Mileage: 148602 km
                    Time Indication: 0
                    Date: 2013.09.20
                    Time: 04:22:39
Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Component: Tuer-SG         007 2101
   Coding: 0132240
   Shop #: WSC 73430 790 1012546
   VCID: 326BACC9AD2F66DA13-8066
Address 69: Trailer        Labels: RETROFIT69.lbl
   Part No SW: SW0 408     HW: 5F0 07V 010 1
   Component: TOWBARMODULE ECS    0010
   Coding: 0000001
Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0132240
   VCID: 3365A9CD52356FD218-8066
Address 77: Telephone
Cannot be reached
End-------------------------(Elapsed Time: 03:26)--------------------------
I'd probably start by unplugging the bt module and checking it's connector is clean and in good condition.
okay that worked, just unplugged the module, and plugged back in, worked. thank you!
