Abs and asr error
I have skoda octavia 2008 and have a problem with abs and asr
After checking  and changing abs sensor and wheel mount disk
Still have same errors
Have anyone faces this errors before
I don't know what is the problem and how to solve it
Log-TMBCA41Z182205583-315080km-195781mi.txt
Any reason you're using a version of VCDS that's 2 years out of date?
For owners of genuine VCDS updates are free for life from VCDS Download
Good enough for a car that's 9 years old though!
Assuming you've cleared codes and re-read - I'd be looking at the wiring down to the ABS sensor, the rubber coating can hide damage.
Using VCDS that old is often, not always, an indication that it's not being used with a genuine cable but with a third-party rip-off clone.
And do we want to be seen to be encouraging the use of rip-off clones???
Thanks for your advice
I'll try this one
The cable I use comes with my used car as a gift
I'll download it and try again
I'll try this one
It works after changing the wiring of abs sensor
thanks alot
No worries. Glad you got it fixed and it was nothing serious 👨‍🔧
If you thing that's bad - you oughta see me read a nissan ABS fault with a staple.
And it's not even a Rexel 😮
Edited by StevesTruck
