how to reset dashboard warning lights
How do you reset warning lights on your dashboard, I have the glow plug light flashing and I think abs sensor light on.
does anyone know why glow plug is flashing.
(Glow plug/coil light) is engine management light, flashing orange. Turn ignition off then back on again. This usually clears certain glitches. But if you have other things wrong you will need to sort them out or the engine management light will just keep coming back on. OBD11 will find your faults and could clear them.
Edited by Ozzy25
If you have VCDS OR OBD11 get the fault codes and get it booked in (especially if the car is under warranty) give them the codes and then they will know in advance what's going on with it and hopefully get the parts in for a quick turnaround.
ok.
