Lower arm/hub upgrade
Hi all,
ive been lurking for a while but this is my first post lol, I was wondering if anyone had tried fitting front lcas and knuckles/hubs from the mk2 tt?
the reason I ask is that they look to be of similar dimensions (not had any available to measure though) apart from the lower ballpoint mount which is lower down on the hub which would reduce camber gain through the suspension travel I believe.
which is the problem I’m having currently, I run my coil overs as low as they can go and this causes positive camber under cornering, which is murdering the outside of my tires even with the lower ball joints as far out as they’ll go!
they’re also made of aluminium so some decent unsprung weight saving to be had too, provided they fit of course lol
There was something about this some time ago, either on Briskoda or UK-Polos forum, and it included which knuckles to use and maybe swop them side to side - sorry that is all I can remember.
Edit:- maybe this will only cause annoyance as I can't point you in the right direction, but I've posted it so -------.
Edited by rum4mo
