Sticky door handle
Drivers side handle has started needing a bit of a yank to release, the handle pull has gone a bit stiff, a pity as all the others have that nice gentle pull to open.
Anyone had this?
Going to spray some GT85 in there see it it helps.  There is a small black plastic cover on the inside of the door, the one that rotates a bit, any idea how to remove this to spray some lube in there?
Same problem for me as well.
Any ideas ?
Did you managed to solve this ?
same here on S3.   Took handle off, greased it and still happens.  Just out of warranty.   Grrrr
Any suggestions?
