ARB 21mm or 23mm on VRS
I have a 01 VRS and the anti-roll bar bushings are gone. Lovely knocking sounds from under the car. I took the wheel off yesterday to measure the bar and it only about 20mm. Is this then a 21mm bar. I would have thought it would have being a 23mm bar due to the spec on the car.
Thanks for all the help
Turbos rock:rofl:
Are you sure its the ARB bushes that are causing the knocking noise and not the bushes in the drop links?
ETKA lists a 19mm front ARB for a 2001 vRS and a 23mm for 2002 onwards. I don't know if the thicker one can be retrofitted.
Maybe i should replace all of them to be sure.
I have a 01 Octy vRS & had both front & rear ARB changed - the front one is VW part from the MK iv R32 & the rear is a Neuspeed one. With standard springs & dampers it is surprising the effect these 2 changes have made :-)
I would definatly recommend changing them :thumbup:
I like the sound of that. Fixing the problem and making the car handle better.
