Ignition Switch Possibly
Hi all,
I have done a fault scan on my Octavia 1.9 TDi  after having some starting issues on got the below report.
I did find the below thread and wondered if I need to do the same so solve it. I have cleared the codes several times but returns everytime I re-scan.
Thanks for any replies 🙂
OBDeleven data log
Date: 2019-11-17 14:44
    VIN: TMBJS21ZX82117088
    Car: Skoda Octavia
    Year: 2008
    Body type: Estate
    Mileage: 250630 KM
16 Steering Column Electronics
    System description: J0527           051
    Software number: 1K0953549BM
    Software version: 0100
    Hardware number: 1K0953549BM
    Coding: 0000002
    Trouble codes:
        00576 - Terminal 15 Electrical error in circuit
            Intermittent
        00883 - Ignition/starter switch (terminal S) Electrical error in circuit
            Intermittent
        00885 - Ignition/starter switch (terminal 50) Electrical error in circuit
            Intermittent
Yup, very likely your ignition switch has worn out.
As per that thread, you can replace the switch on the end of the ignition barrel easily enough. I think there are a few different styles so it might be worth checking what is fitted before ordering 🙂
Wow thank you so much for such a fast reply!!
