'94 Skoda FORMAN front control arm bushings
I have had to replace the rubber front lower control arm bushings on our '94 FORMAN several times.
Our rural Colombian roads are dirt and ROUGH. They beat the Forman's suspension unmercifully. It's held up very well considering, but goes through control arm bushings like crazy. only OEM bushings are available here. Does anyone sell heavy duty polyurethane bushings for our Forman?? Are the Skoda pickup truck bushings any tougher??
- JAMES
On 23/11/2019 at 13:08, nu99et18 said:
Assuming Foreman bushes are the same as Favorit then you can get then here https://speedpro.eu/produkt/tvrde-silentbloky-zadni-napravy-skoda-felicia-favorit/
That's if they will ship them. Oh and make you select Favorit when checking out.
Nu99et -
Thanks for the reply. Your link was for the REAR bushings, and I need the front. I checked the site, and the front bushings are not available. Thank you for your help. I found a site called SIBERIAN BUSHINGS that may have what I need.
- JAMES
You mean these:
https://siberianbushing.com/catalog/SKODA/EUROPE/FELICIA/FELICIA/-
They are on Amazon too from the same company.
https://www.amazon.com/Bushings-21-01-1686-2-Front-Swaybar-Felicia/dp/B01MS0XKS9
https://www.amazon.com/Bushing-22-06-2626-Front-Susp-Felicia/dp/B00X9JBQGQ
18 hours ago, JAMES399 said:
Nu99et -
- JAMES
Sorry I was meant to send this link, https://speedpro.eu/produkt/tvrde-silentbloky-predni-napravy-skoda-favorit-felicia/
This has the front and rear wishbone bush. Not sure on availability was in stock when i bought some.
