Speed Limit Display from GPS Map
I'm sure I've seen this asked before but can't find it now...
My car doesn't have the lane assist camera, but is there a way to show the current speed limit from the GPS map on the multi-function display?
Don't think so, you need the camera for Traffic Sign recognition to read the Speed signs.  What year is your Vrs ?
Its 2016. I thought there might be a way to use the speed limit info from the gps rather than using the camera to detect them?
I don't think so. My vRS has the camera and the MIB1 Amundsen and I've enabled traffic sign recognition, but it throws up an error every drive because the MIB1 isn't able to combine speed sign data from the GPS and camera at the same time (although it displays the camera data just fine). I've searched throughout VCDS to try and find a way to have the speed sign on the MFD pulled from just the nav data without using the camera at all but I couldn't find anything.
If I turn traffic sign recognition off then I get the speed sign back on the nav but not the MFD. As soon as TSR is enabled the nav seems to be unable to display any data without the camera (even though it is supposed to combine the two). If I turn off the camera settings for TSR and leave everything else for it coded, it just throws up errors and won't work at all. It's apparently a thing with MIB1's.
This makes me think it's probably impossible to pull the data to the MFD without the camera and fully coding TSR, unfortunately.
Edited by FluffyEyeball
Useful explanation thanks 👍
