Where is my ABS plug?
Hello.  Skode Fabia 2003 1.9 PD engine.  Traction control light is lit dimly with ignition off.  Any info please. Where is abs pump electrical plug please?  Thanks
wrong forum......
Is this a Skoda site?
It is but you're in the wrong part.
Don't worry though as I'll move it for you. :thumbup:
Many thanks John.   😕
  • Sponsor
Left hand drive car or right?
Hello Wino.  It's right hand drive.
  • Sponsor
As you look from the front of the car into the engine bay, the ABS module is on your right, at the back, below the engine ECU.
Edited by Wino
  • john999boy changed the title to Where is my ABS plug?
Many thanks Wino.
There are common water ingress issues in the wiring loom under the module itself.
Would be worth a fault code read though as there are other systems that can cause the light to come on.
