Led
Has any one changed the front fog lights to led's at all?
You have a VRS or standard?
It’s the standard model.
You're able to change them easily enough, H8 bulbs if I'm right.
You will need to code them to the car, otherwise the canbus will throw a wobbler
Cheers tunedude. Had half a feeling they would need to be coded!
Is it hard to get leds coded?
It shouldn't be difficult using OBDEleven or VCDS using the below guide. However you'll need access to either of the above to do the coding.
I shall be doing this as soon as my bulbs arrive.
