Brake pad warning light
Hi all the brake pad warning light is on in my 2007 vrs. The pads are good and the sensor is already disconnected and the wires joint! Do the wires break further up the line or can an app like carista turn off this feature? I don’t have vcd thanks
When mine happened it was just the NSF cable had a break in it, jointed it out and the light went out.
We're have you made your joint? beginning and end so taking out the rest of the system? Fuse gone maybe?
Hi thanks for the reply! Yes I joint the wires right after where the y section where it splits for the abs! I will check the fuses tomorrow r possibly another break further up in the wiring
Hmmm good luck with the diagnosis, let us know how you got on!
