Airbag warning light won’t go off?
Hi
My first post so sorry if the answer is somewhere in the forum.
I replaced  the heater/blower resistor in my 2013 Fabia, removed the passenger airbag to replace it. However once it’s all been reassembled the airbag warning light comes on, goes off for a couple of seconds then stays on permanently.
What have I done wrong and can I reset it?
you disconnected / reconnected it with the battery connected ?
If so it has logged a fault and is latched, will need resetting.
That’s what I thought, I was too lazy to disconnect the battery, I’m guessing my local garage can reset it for me or would disconnecting the battery for a few minutes reset it?
no it needs plugging in
Thanks, very much appreciated.
...lucky the airbag didn't fire off. That would quite literally, have left you red-faced!
That would have smarted...
NOW FIXED
