vRS 245 Performance Gauges In Infotainment
9 minutes ago, langers2k said:
The compass is normally built into the satnav so without nav, you won't have one :)
Awwww, oh well. Back to un-code some stuff then 😅
Thanks,
Jay
  • 6 months later...
  • Replies 51
  • Views 16.8k
  • When the two most popular tools in VCDS and OBDeleven both refer to the process as 'long coding' (as distinct from setting adaptation channels) I think it's safe to say everyone knows what is meant by
  • Menu Display Compass - OFF ROAD WITH AND WITHOUT NAV 1 - Module 5F - Electronic Information 1. Code (20103) 2 - Adaptation 3 - Select - Car Function Adaptations Gen 2 4 - Search submenu - Menu
  • What RocardoM is doing wrong is not taking notice of the context.   In the context of changing the setup of vehicles "coding" means a USER changing a setup string.   In the context
On 2019/12/27 at PM5點48分, SashaGrace said:
如果您擁有 MY19 245 then 或任何帶有 04xx 固件的 Amundsen,那麼您可以使用 VCDS 液位工具激活 Off Road 屏幕並啟用水溫和油溫計。如果您希望使用單獨的選項卡打開運動屏幕以及 G 表和圈速計時器,那麼您將需要 ODIS-E 將 FeC 添加到收音機。解決方法要容易得多,並且可以使用較新的 Amundsen's 上的家用工具為您提供真正需要的一切。
Hello, can I ask you the correct way?  Regarding sport, I have odis, thank you
