Locked door
Good evening all.
Is there anyway to open a door that deadlocked and won’t open with internal handle ??
My Superb has lost power to both passenger doors and i cannot open manually to check the door loom for broken wires.
It sounds strange that both doors would suffer a broken wire at the same time. Are you sure that it is not something simple like a blown fuse? A VCDS scan may also give you some indication as to what is wrong.
Yes, but the "wrong wire" breaking in the RHF loom can disable both front doors.
So no more hydraulic tools advice? Is that all he can do?
Would that wire breaking also disable all power to both passenger side doors as the OP has reported?
You seem to have a lot of fault codes relating to non communication on the can bus lines on the scan. Have these just occurred?
You may like to search the Ross Tech site for an answer or ask on their forum.
I’m plumping for broken wire/s between door and A pillar. Problem is nobody can tell me how to open the door to get at the wiring !!
