Fault automatic headlight control
Elegance 2013,this just come on dash all lights still working could it be the sensor if so i take it its behind the mirror and its the rain sensor as well, any one got a parts number please or could it be the switch thanks and happy new year
Rather than trying to second guess you really need to scan the car for fault codes.
Do you have or know anyone with an OBD fault code reader, i.e. VCDS, OBDeleven, Carista etc.?
Tried that no codes show up so will probably have to take it to be read, thanks anyway
What are you using to read the fault codes?
Is your car a MK2 FL or MK3 as both could be a 2013 car?
Hi mk 3 july 2013,basic reader, when it gets dark then i get the fault message when first engine first turned on, thanks
