Mirror indicator cover
Hi, I am looking for a n/s mirror indicator light cover for my mk2 elegance estate. Something like this:
https://www.ebay.co.uk/itm/Left-PASSENGER-SIDE-WING-MIRROR-INDICATOR-Skoda-Octavia-mk2-2004-2008-lamp/391608024380?hash=item5b2da83d3c:g:s5oAAOSw51JbaqJz
I understand that some have built in puddle lights and some don’t, which affects whether the wire connection in the mirror is a 2 pin or 3 pin.
My car does have puddle lights but does anyone know the part number so I can source the correct part for my car?
Thanks in advance!
Thanks in advance!
Just in case you hadn't seen the note this ebay item is for NO puddle lights.
Take a look here to see if you can identify the part you need.
The parts diagram (pre-FL) is here - item 12 I believe - but it unfortunately doesn't give any details.
Finally, once you get a part number take a look on aliexpress.com ; if the part is listed there it will be cheaper than anywhere else.
Thanks Sticky,
I have found 2 part numbers but not sure which is the right one for my car:
1Z0949101D
3T0949101
Any idea?
