Window switch failure.
Hi all, just noticed that the rear offside passenger electric window works from the control panel on the drivers door but not from the passenger door. Is it likely to be simple failed switch?
If so, is it replaced by levering out the old switch from the top - an easy job?
John
Could be the switch, really depends on usage and if its worn out......to be sure you could
its the same switch as in the front passenger door and other rear door, so you could swap them to confirm switch is faulty on rear door, if the fault remains, then could be broken wires in the door connection.
Lever the switch out carefully from the back edge and then when un-clipped ( popped up)  it comes out up and rearwards as there is little tangs that sit under the trim panel.
Edited by UrbanPanzer
