Octavia 2 vrs rear interior lights have stopped working
Front interior lights are working perfectly but the rear have packed in, do any of you guys have any advice?, thanks.
New bulb.......:thinking:
Doh, why didn't I think of the most obvious,  😚
Thanks Tilt.
Update.
I hadn't had a chance to have a look at this problem until last night and I notices that it has 3 bulbs, I thought it a bit strange that all 3 bulbs had blown so I left it until today.
It was quite obvious why it wasn't working, there was no bulbs in the fitting.
I've had the car since last September and never noticed it wasn't working, so i've ordered some led's to match the front.
Switched off?
Depends if you mean the rear (courtesy) lights dont work when a rear door is opened or they also cannot be switched on as reading lights.
Edited by J.R.
On 11/02/2020 at 19:03, J.R. said:
Switched off?
Some body had removed the bulbs before I bought the car.
Led's arrived today, fitted and working perfectly, cheers guys.
Sometimes the simplest solution.........glad you sussed it.
Truthfully I hadn't looked at it before I posted on here but when I checked it, I thought it was strange that all 3 weren't working, then when I noticed that they were all missing I wondered if there was a problem with it.
This is my first Skoda after having Vectra's for quite a few years.
A case of look first then open my gob. Cheers Tilt, 😁
