Gearbox Diagrams wanted
Hi All,
Mk1 2004 Octavia vRS
I have an issue with my gearbox which currently will not go in to first all other gears are perfect?
I have already tried the following to remedy the issue but still no first?
1. Adjust & re-adjust the linkages multiple times.
2. Changed gear oil.
3. Changed selector tower.
Basically the gate feels blocked like on the 6 speed when the rivets sheer & the fork is not connected to the shaft.
I have been trying to find an exploded 02J EHA or any 5 speed 02J diagran to see what might of gone wrong before I pull the gearbox out for the 3rd time
1. broke orginal
2. replaced with SMF & 2nd hand box (lasted 6 weeks before the cup bearings shattered holing the bellhousing & jamming the diff.
3. replaced with original box to be mobile.
All advice & ideas welcomed,
Al
Stickymicky That is spot on thank you mate
  • Administrators
Boxes are known for their bad syncro's which causes a bad crunch and selection issues... Eventually I will get my gearbox stripped down and replace with stronger parts.
Edited by DeanVRS20VT
