Oily idiot
Two weeks ago I topped up the oil on my Octy as it was near service and getting a little noisy.  I know that they burn oil and it gets lower before a change is due.
Last few days, however, the oil light was intermittently flashing - odd.
Turns out that I forgot to put the oil cap back on, there were flecks of oil all around the engine bay and the tray under the engine was very oily.  Thankfully I'd not lost the oil cap.
Today the I changed the oil and gave it a good clean.
My question is: do you think that any dirt would have got in whilst the cap was off?  If so, would it be worth replacing the oil (or just the filter) in a couple of weeks rather than waiting 10,000 miles?
Many thanks,
Mark
PS it may cheer me up to hear if anyone else has done remarkably daft things with their cars........
Edited by mark674500
Sorry, forgot to say that the underbonnet area is so well protected, the area around the filler cap so well shrouded (why you did not lose the cap) that I doubt any measurable quantities of dirt will have got in, the crankcase has positive pressure, any that did will have been caught by the oil filter before being circulated around the bearing surfaces, I cant see the need for an oil change.
Forgot the ultimate oily idiot tale.
Friend whos father had left the mother, he had no male role model and by 17 was the male head of the household, mother could not drive.
He bought an old Marina after passing his test & recounted the following tale to me:
He decided to top up the oil before driving it, "blimey was it low J.R.!, it took all of the can so I walked into town and bought a can at Halfords (5 liter) and it swallowed all of that as well!"
You can probably see where this is going now 😀
"So I walked into town again and bought another can (5 litre) and it took most of that before it was finally full, I started the engine (WTF!!!! - it actually started!!!!!!!! 😯) but it was making a really funny noise and then I saw oil spurting out everywhere" 🤣🤣🤣
The rest is self explanatory.
Edited by J.R.
I had to rescue a mates car when they filled the engine with oil 🤣
I've done a few stupid things in my time, the most timely one, I had a beautiful D3 A8 it was a 3.0tdi, they commonly suffered with chain rattle on startup, I went down to Audi and purchased two new tensioners for each bank, I had the timing tool kit and everything.
i look down at the crank pulley and there is loads of stuff in the way, I then decide the easiest way is to remove the tensioner, don’t touch anything and put the new tensioner in again without moving anything, I mean I did it on my old push rod ford engine without issue.
so that’s exactly what I did, I thought that was well easy, jump in the car fire it up and it ran like a bag of spanners, after the realisation set in that cylinders 1-3 weren’t firing, it transpired the moment I turned away to pick up the new tensioner was the moment the sprocket moved and as I fired it up I just kissed all the inlet valves enough to bend them and loose compression.
at this point I had no option but to get access to the crank pulley and it was annoyingly easy and not that complicated after all 🤦🏻‍♂️
and to top it all off I needed a £1000 tool to remove the cams so I had to buy a complete head and swap the heads over as it was cheaper, it ran lovely after all that work but I fell out of love with it and during it’s down time I bought my first petrol turbo car, a Leon Cupra and enjoyed it so much I’ve had petrol turbos in my garage ever since 😎
Just to add, as it was only two weeks ago I’d also be inclined to just chalk it up to experience and not worry about it any more 👍
Thanks for the replies, I feel less concerned about the oil, and more importantly had a good laugh about all those stories!!
