Oem xenon lights question
Hi folks! I have just bought an superb again! Was missing mine ‘03 awx classic and found an ‘04 awx elegance manual at good price. It has xenons, when I switch to high beam (full beam?) the fuse on right high beam blows. Tried to remove halogen h3 bulb, same result, flashing or switching to high beam trips the fuse. Tried 35Amps fuse, same story. Finally managed to disconnect headlight plug on the back and fuse doesn’t blow, I assume this means problem is not in the wiring or switch?. I was wondering how exactly operates the high beam in this headlight?  If someone can help or share similar experience before I tear down entire headlight will be great. Greets!
