Broadband Disconnecting?.
My Broadband connection keeps on disconnecting for no apparant reason. Today it seems to be happening more regularly than ever, about every five minutes or so. I am also fing it harder to connect when switching on, any idea's from you computer boffin's?.
Have you plugged anyhting else into the phone line recently Steve? Could possibly be a micro filter breaking down. I used to have trouble with the Sky box causing interferance too.
No, havn't added anything to phone line although I do have Sky+ but have had no problems in the past!. It's a real pain as every five minutes it keeps bloody disconnecting!.
There appears to be a link with my E-mail (Outlook Express), every time I click on Send & Receive it's disconnecting. Any idea's?.
Sorted.
I had been making some changes to my E-mail and checked the "Disconnect after Send/Receive" by mistake :doh: .
If you are using a USB broadband modem, it could be Outlook Express that is causing it. Look in the Options of OE for an option that says "hang up after send/receive complete" I bet it is ticked! Untick it and it should be sorted :)
If it is already unticked, then I dunno.
EDIT: He sorted it as I was posting :D
If you are using a USB broadband modem' date=' it could be Outlook Express that is causing it. Look in the Options of OE for an option that says "hang up after send/receive complete" I bet it is ticked! Untick it and it should be sorted :)
EDIT: He sorted it as I was posting :D[/quote']
Thanks for your reply though, most appreciated :thumbup:
I'd always recommend using an ADSL router (= router + ADSL modem integrated) and using a wired or wireless connection. Generally more stable too.
That said USB can work fine with a single machine :) & glad you're sorted :thumbup:
USB in my experience is a disaster. Send something to the printer and bang the broadband drops out. Use the scanner and bang the braodband drops out
A lot depends on chipset, driver quality and OS.
That said a NIC is written for a single purpose and should do it well, they're cheap (a fiver will get you a reasonable chip on it) and it won't have any weird OS-dependant funny behaviour going on.
Old VIA chipsets used to be a bl*dy nightmare with USB and I've avoided them ever since for that purpose. New ones are fine though.
Best move I ever made getting a router and modem. Seemed to speed things up a little.
never experienced a problem with my usb modem when using any other usb devices ,although it did disconnect intermittantly when broadband first installed seems ok now:thumbup:
