Clutch Failure
Thanks in advance for your advice.
I purchased the new Karoq 1.5 TSI Petrol late 2018 and in January of this year it rapidly began to judder in high gears and then failed completely. Investigations have shown a worn clutch.
It has less than 8500 miles and was 13 months old.
It has always had a high biting clutch which I assumed was normal for the car. Since repair, however the biting point is much more mid range.
My wife and I who drive the vehicle have 50 years of combined driving experience and we have never had a clutch fail so to be told by Skoda that this is due to "driver influence" was very disappointing.
Skoda are refusing to accept any liability and believe it to be a wear and tear issue and thus not covered under Warranty.
Is there anything I can do about this?
Is there anyway I can prove that the high biting point caused this?
Could Skoda's investigations exclude this? - At present they are telling me that the clutch plate and flywheel show significant signs of disintegration, and would be considered to be ‘blue’ in appearance. I don't really dispute this but I truly believe that the underlying cause is not down to "driver influence".
I found an almost identical case here;
Yours frustrated!
Nathan
All that point really proves is that you have a different clutch assembly (and possibly flywheel) in the car.
If we accept the report that the old flywheel was blued in appearance, that definitely means that it has overheated. I'm not saying whether that was due to driving technique or not, just that it does show signs of overheating.
There are plenty of examples of some clutches not lasting. The problem you have is proving the clutch rather than the driver was at fault.
You say the clutch always had a high biting point. Whether or not that is of any significance is irrelevant if you hadn't already reported it as a potential problem.
And with the car being over 1 year old, that's more than enough to burn out a clutch.
If I were in your position, I'd have asked for the failed parts to be returned and said I'd be submitting them to a specialist for examination. And depending on their report, I'd first be asking the dealership to contact Skoda( or do it yourself ) requesting goodwill citing as many other examples of early clutch failure as I could find + stating you never had such a failure in your life. It might also be worth telling them you're submitting your example to the motoring press ( pick one where premature clutch failure has already been highlighted ).
Not sure you'll be sucessful but it's defo worth trying.
Skoda know they have an issue with some of their clutches.
By why admit it and pay for their replacement? It's far easier to blame the driver and play the usual old 'wear and tear' card.
It's too late now, it sounds as though you've already had it replaced. As above you should have asked for the old clutch back and paid for it to be independently examined.
Even if it was found to be attributable to a mechanical or design defect you'd probably still have to pay a solicitor to send a threatening letter to Skoda UK.
There have been several failures on the Kodiaq too.
  • 6 years later...
Me and my wife loved our 2011 Skoda Karoq estate. So when we decided to replace it with an SUV in 2023 it was natural for us to buy a Skoda SUV. We bought a 2022 Karoq 1.5 SE Technology.
We have always loved the car, but when the clutch went without warning at around 30,000 miles, we were shocked and disappointed. Although my wife (whose main car it is) admits to riding on the clutch at times, she has not changed her driving style over the years. We sold the Octavia at 118,000 miles with no sign of a clutch problem.
Edited by Martin1969
Welcome to the forum.
What was the mileage when you bought the 22 Karoq ?
Edited by Warrior193
correction
AFAIK, the Karoq was only introduced in 2017 - presumably your first (2011) vehicle wasn't actually a Karoq?
I got a mental block. Don't know if I can amend it now. Our 2011 car was an Octavia estate. The Karoq had about 8,000 miles when we bought it in 2023.
Plenty of scope for the first keeper to take a few lives out of the clutch in 8K - compounding that with 'riding' it occasionally in your ownership would easily finish it off.
An expensive bad habit.
Possibly the weight of the Karoq clutch is lighter than the Octavia's was, and even only a slight, inadvertent pressure on the Karoq's clutch pedal was causing excess wear.
Thank you for this. My wife is now trying to stop 'riding' the clutch. Hopefully it won't need another new clutch in another 30,000 miles!
Perhaps consider fitting a bigger aftermarket footrest for left foot?
or DSG car
I would love an automatic, but my wife doesn't like them. However, if her left leg pain gets any worse, there may be no choice! Wouldn't bother me.
