Cornering lights
Hi all, I have an 2017 Octavia estate, my cornering lights doesn't switch on when turning. Di i need a special lights for it to work or is it just a case of coding?? Thanks in advice.
What model is your Octavia?
Does it have front fog lights?
If it does and the fog lights don't come on at speeds under 30mph when you indicate or turn the steering wheel (with dipped headlights on), then they'll need coding.
2017 Octavia SE L
I do have a front fog lights but didn't notice they are coming on when taking a turn.
Coding?? Can I do it myself or do I need to go to the dealer??
Thanks.
Hi,
you will need VCDS to code them in, look on here to find someone near you and they will normally do this for some beer tokens.
John
