Vw polo 9n Automatic transmission oil leaking
Hello machanic please help my vw polo round light auto transmission oil is leaking  how can you help who encounter the same problem please help.
You need to go to a local mechanic and see where exactly the leak is coming from then go from there.
Is this a 6 speed tiptronic gearbox in your car?  Which engine?
https://www.clubpolo.co.uk/topic/295085-mk4-polo-16-auto-gearbox-oil-grade
EDIT,
OK, i see now a 1.4 16v bky engine.
EDIT,
ok thanks because it is covered with oil the sump
Do you actually know if that's engine oil or gear oil? What it is will be way more diagnostic than where it is. For example, a leaking oil gallery core plug could cover the gearbox in oil, but the cure is to replace the core plug (About GB£1 for the part and 15 minutes work) and not worry about the gearbox itself.
