Mk 1 Skoda Octavia Vrs Pollen Filter Access
 just wanted to know,the black trim at the base of the windscreen where the pollen/pollution filter resides on the vehicle in title,is it secured with clips.doe's  it  pop off,thanks.
Edited by macatac
This may help -
Great stuff,cheers for that.
On 09/03/2020 at 20:57, kentphil1 said:
This may help -
He makes it look so easy. Mine is far fiddlier...
There is a knack!
Just warm the screen trim with a hairdryer if the conditions are cold, then gently feed your fingers under the trim as you lift it and the rest is the same as the vid.
Done my filter 3 times since i've owned the car. I just make sure the filter is fitted perfectly to the upper frame before I clip it home.
