Brake fluid quantity?
Hi all,
I'm about to change the brake fluid on my Mk3 (TDI190 4X4 DSG6) by myself. Does anyone know the necessary fluid quantity? I have no idea.
Thank you for help. ;)
don't know amount, but i can share price -
        € 15.62    job 0.5h
        € 25.91    fluid B 000750M3
Great! M3 corresponds to 1l bottles . Can you confirm that quantity is '1' on your bill?
I would definitely know the required volume.
Thanks! ;)
Hi all,
I've found the detailed answer to my question. 😎
I remembered of this link to the Maintenance manual for Superb 3, found on this brillant forum.
Operating practice is described from page 126 to 137. Brake fluide volume is 1.0L for DSG gearbox and 1,15l for Manual gearbox.
Torque for vent valves screw is 4,5 Nm. 😉
However, still one question. At the end of the Operating practice, it's mentioned: "During a test drive, at least one ABS adjustment must be carried
out on vehicles with ABS.
Does anyone know what 'ABS adjustment' precisely means? 🤨 Since it must be performed during test drive, I assume, one needs to press the brake pedal hard enough to trigger the ABS system at least once... Am I right?
Please advise! ;)
Edited by Bap33
I think you're right, it's to make sure no air has entered the ABS unit - you are in trouble if this happens.
