engine code
hi all could someone point me in the right direction please.
i am trying to find were the engine number is as i am trying to find out what year the engine is as i have replaced the engine. a didn,t replace it personally a garage did .
a picture would be helpful thanks.
thanks for the reply done that but seems theres nothing on my engine a mean theres no numbers or letters there thanks.
Isn't it on the V5?
The original engine is but not this 1 that's been fitted.
Haynes manual you tube and others are saying were it is but when a look for it on the engine a can't find it just the part numbers of that part.
Thanks.
Usually a printed bar code label on one of the cam covers so likely to have been lost with an engine swap.
If you know what engine it had that will narrow down the range of engine codes that could have been fitted and you could then research the physical differences between them to identify what one you have.
Edited by J.R.
The first engine which was a BXE that was my original engine which packed up so got a second hand 1 fitted but don't no nothing about it.
A only want to no what year it is.
Got more chance of winning the euro lottery.
The garage that fitted the engine didn't no nothing about it he just got it delivered.
Bit poor that the garage took no care where the engine was sourced from.........suppose if they fit that many.
@Taximan1978 what does the BLS refer to???
BLS is supposedly the engine code but am trying to find the correct numbers and letters stamped on the engine so a can find what year the engine actually is.
But that's what am having trouble with a just can't find it.
Thanks.
Need to find receipt.
