disable stop start
Just a quick one for you technical boys, ive got a new sportline 272 and want to permanently disable the stop start, i previously had a 17 plate sportline 190 cr and i disabled it using vagcom by adapting the voltage limit from 7.6 volts (default) to 12.1 volts, Did this on the new car all adapted and accepted ok but it still operates, has anyone got any ideas how to do it if it is possible.
That is normally how you do it on a Superb. Are you sure the values stuck? Or try 14V ?
Edited by digifish
Apparently for MY20 cars you cannot code it like that.
So they are fighting us :)
You can’t change the value to anything over 12.1 as I already tried that lol, wonder if you can change the temperature value
Do they still fit the battery monitor connector on one of the battery posts. I disconnected it on a MY13 Leon petrol. Did the job.
Worth a try mate, thanks.
