VCDS
Hi dear members!So I did adaption with vcds and now I have issues with lights.I did adaption with leuchte.Can anyone please help me?What settings should be for Skoda Octavia III 2014?Thank you!
If you want people to help you we need more information e.g.
What model, year, engine and trim level is your car?
What version of VCDS and interface type are you using?
What have you altered using VCDS and what were you trying to achive?
It would help if you posted a full autoscan and an adaption map for the module(s) that you altered.
Luckily, VCDS keeps logs of any codings or adaptions that you have made ( at least in my version, it does ). Depending on your Windows OS, they are located in the Ross-Tech folder - VCDS folder - Debug folder - AdpLog.csv  and CodingLog.csv. Have a carefull look through those last two files and make a note of any changes that you have made in each log and then just reverse them. That should sort your problem out.
