Warning light when cornering
Hi guys, my 2004 1.9 Octavia produces a warning light and three beeps when cornering. I'm thinking it's a blockage in the oil pickup. Does anyone have any other suggestions?
2 minutes ago, mac11irl said:
hi,
which engine code 1.9 is it,
which warning loght comes on
 It's an ALH, and it's this light image.png.cb0be0521be8e61ae6f17b2bc756fe43.png. Just looking now at the manual it says it's a brake fluid warning, but as far as I can see there is plenty of fluid.  on further consideration, it's more likely something to do with the abs system.
Before you go to the expense and hassle of changing wheel bearings, check your handbrake lever and handbrake switch. If it's ratting around of the switch is a bit dodgy, the forces generated while corning could be enough to activate the switch, which is also another possible cause for the warning light coming on.
The brake fluid level will be low or the sensor is duff. I wouldn't of thought an ABS fault would give you the three beeps and as well as the light.
Edited by SuperbTWM
