Ignition problems
Went in car yesterday driving fine went to go back in key wouldn’t turn not even a little just enough steering lock off recently had new gearbox new clutch new clutch pedal I’m a taxi and nearly on 300k Nk10jwx I looked up to remove barrel can’t line up holes with pins do you think I’ll need a new part or maybe something easy I’m at a loose end any help appreciated thanks tony
sounds like either the barrel or steering locking mechanism has failed.
Here is a guide in how to remove the locking mechanism from the car to replace
Managed to start car wd40 in the lock cotton bud to clean it still wouldn’t turn key in hammered the lock turned over still stiff like for now gonna order a barrel and try that thanks for help
IVE ordered one key was abit sticky thanks for your help tony
