EPC Light
Hi All
So yesterday went out to use the car in the heat and the EPC light was on. After running a scan with Carista it showed a P0111 Intake Air temp Issue. HAd to go out today and the light was initially on when it started but went off after about 1 minute of driving.
Now the car has only done 835 miles and my local Skoda dealer is still closed. As the light is off again do I need to worry about it now or leave it until my local deal is at least open or until it goes in at some point? Wondering if they won't bother if not showing as an active issue.
10 hours ago, glenn_btn said:
Hi All
https://www.obd-codes.com/p0111
If the car was in the shade or in a cool area, was started up and then immediately taken out into hot hair, i guess it could potentially trip it. If it doesn't appear again i'd not worry about it. If it keeps popping up, dealers should be opening up early june.
