Port Forwarding
I've been messing around with port forwarding on my home setup. I have a Netgear DG834v2 ADSL Modem/Router connected to a Netgear WPN824 Rangemax Wireless Router.
My question is - If I open or forward the ports on the WPN834 do I also need to open the same ports on the DG834?
What is it you want to do?
Personally I use UPnP as it sorts port forwardig for you....if you're networking to some sort of IP device.
I am trying to use P2P. The software does have UPnP as do the the routers but I couldn't seem to get it to work.
uPnP service in windows enabled?
I've enable the UPnP user interface in control panel/add remove programs/components.
I don't use windows firewall so I shouldn't need to do anything there - will my AVG firewall stop it?
I have been doing a lot of reading up and most places say I should use a fixed IP in the 192.168 range on my PC - would that be right or should I leave it up to DHCP?
I used to have my setup like this -
phone line->Modem Router->Wireless Router->PC
I've now changed it to -
phone line->Modem Router->PC
Which is the optimum configuration?
Stu,
why are you using the wireless broadband router?
Just for more connections or for a wireless connection to your pc?
Your ADSL Router is DG834 which should have wireless capability..right?
Doesn't matter about a fixed IP address range...DHCP is fine..unless your hosting something but then you can always use DDNS to sort that.
No the DG834 is not wireless Adrian, the DG843G is though.
I jumped a bit early and bought a MIMO Rangemax before they launched a combined modem/wireless/router. I wish I had got the Linksys SRX unit now.
My PC is wired to the router and i only use wireless for my Laptop.
I have D-Link MIMO ADSL Router and it works fine. Should just utilise the slowest path in your LAN.
Going back to the wireless side...you could have used a wireless access point instead...Belkin do a MIMO access point.
Yeah. Could have done lots of things on reflection but I'm stuck with this little lot for now. :P
Aye.:D
Back to your configuration...TBH I don't think it makes much difference between how you had it set-up originally to now.
I have it set up in the second configuration and it's working well, downside is I can't see my USB printer that is attached to my PC from my laptop.
This is a useful resource for anyone with a home network that is having difficulty with port forwarding chaps....
Clicky
DG834 Setup Guide
Been using that one thanks Tony :thumbup:
Remind me when I'm down next Stu, will have a look if I spot anything. I've got a three-broadband connection network at home, involving a cable modem, two ADSL router/modems, two loadbalancers and a few other bits and pieces + a few wireless networks :rofl:
(yes that's overkill for at home :P ) - should be able to get you going.
Yeah that would be an idea, ta:thumbup:
