H15 LED fitted
16 minutes ago, skippy41 said:
Ordered these last week, arrived today, fitted and working a treat, thought the DRL where not working then remembered the hand break was on, no dash warning light
How does main beam look with these fitted?
i have mine installed for 6 months now 😀. the difference is amazing.🤪  Cornering is clear as day. 🧐 It's worth to change them.  I had to code mine to LED though. . After that i had to polish my foglights because all the stones were toooo visible 😛 😛
The H15 bulbs go in the headlamps not the fog lamps ???
My bad , you are right 😴. i saw the picture and thought those are for the foglight.  ( mine were exactly the same, but for foglight.  Socket H11 i believe)
checked. H8 for Foglights. Not H11
Brilliant,  with  H7 led, and the H8 fogs
It was cloudy and quite dark last night, so went for a drive, what a massive difference being able to see clearly on high beam , made  the normal bulbs feel like candles
So you've fitted LED H15 & H7 in the headlamps and LED H8 in the fogs?
 Yes, you have to find the right LED H7s for reflector lenses, the ones I eventually found have exactly the same kick off as the normal bulbs, but give a dam sight better light on the road on dipped beam, not got the box anymore they came from HIDs for u
