ABS/ESP/TPMS lights at once :(
Octavia vrs mk2 fl tsi (2010).
Driving along I got the ABS, ESP and TPMS lights up at once :(
Scanned and saw the below (VCDS autoscan error sections below).
I had a look around and apparently the teves ABS pumps are known to fail.
Would mine be impacted or would it just be the sensor/ring?
If it is the sensor/ring - am I correct in understanding that:
- the hub and bearing need replacement?
- the sensor would need replacement too?
Monday,20,July,2020,19:52:16:42399
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.1.0 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: [redacted] License Plate:
Mileage: 193680km-120347mi   Repair Order:
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: [redacted] Mileage: 193680km-120347miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (CCZ)       Labels:. 06J-907-115-CCZ.clb
   Part No SW: 1Z0 907 115 AF    HW: 1Z0 907 115 F
   Component: 2.0l R4/4V TFSI     0010
   Revision: AAH16---    Serial number:
   Coding: 0203000C1C070160
   Shop #: WSC 73430 790 00999
   VCID: 79FE6174307CCD4E4C-802C
1 Fault Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
               U1017 - 007 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100111
                    Fault Priority: 0
                    Fault Frequency: 5
                    Reset counter: 255
                    Mileage: 193576 km
                    Time Indication: 0
                    Date: 2014.12.10
                    Time: 19:58:18
             Freeze Frame:
                    RPM: 2753 /min
                    Load: 27.0 %
                    Speed: 104.0 km/h
                    Temperature: 95.0°C
                    Temperature: 30.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 163B601C092300FA681106E790210081340800
   VCID: 78F86470CB76D44633-802C
1 Fault Found:
00290 - ABS Wheel Speed Sensor; Rear Left (G46)
            003 - Mechanical Failure - Intermittent
             Freeze Frame:
                    Fault Status: 00100011
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 189
                    Mileage: 193443 km
                    Time Indication: 0
                    Date: 2014.12.10
                    Time: 10:27:09
             Freeze Frame:
                    Count: 0
                    Count: 0
                    Count: 4608
                    Count: 69
                    Count: 50519
                    Count: 0
                    Count: 64768
                    Count: 0
Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0575
   Revision: 00103 AG
   Coding: 44180A98B05BB1C040080081050001E4432800AE424D8960800440040000
   VCID: 326C96586D8AFE16CD-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 17031  22  0601
   Coding: 00D7B7
   Subsystem 2 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 3 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HO  H05 1501
No fault code found.
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2114
   Coding: 0000756
   VCID: 4898D4B03B1664C683-801C
1 Fault Found:
00109 - Left Mirror Turn Signal Lamp (L131)
            012 - Electrical Fault in Circuit - Intermittent
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 74     3001
   Revision: 00H17000
   VCID: 316E9954A88CC50EB4-8064
1 Fault Found:
01316 - ABS Control Module
            013 - Check DTC Memory - Intermittent
             Freeze Frame:
                    Fault Status: 00101101
                    Fault Priority: 3
                    Fault Frequency: 6
                    Reset counter: 229
                    Mileage: 193605 km
                    Time Indication: 0
                    Date: 2014.12.10
                    Time: 20:15:12
             Freeze Frame:
                    Voltage: 13.88 V
                        DU
                    Temperature: 60.0°C
                    RPM: 3264 /min
                    Speed: 111.0 km/h
                    Speed: 111.0 km/h
                    Count: 0
Your fault code is:
It's very common for this to occur.
You need to replace the entire bearing as the ABS ring is built into it and you can't replace it. You can get them easily. Pattern parts are available for around £25.
Sometimes a good cleaning can solve it as mud and debris can be collected and so sensor misreads.
On 21/07/2020 at 10:30, softscoop said:
Your fault code is:
Entire bearing was replaced. Old one was heavily rusted.
Problem hasn't shown up since :)
Edited by bspman
Glad to hear you got it fixed.
Thanks. Now I've got to try and sort the fabia out!
Update. It has reared its ugly head again.
Time for a new sensor? The low pressure alert was due to a tyre with low pressure not long ago.
   Revision: 00H30001
   VCID: 78F86470CB76D4462B-802C
3 Faults Found:
02214 - Tire Pressure Warning
            002 - Lower Limit Exceeded - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 240
                    Mileage: 193772 km
                    Time Indication: 0
                    Date: 2015.01.16
                    Time: 10:09:54
             Freeze Frame:
                    Count: 0
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50734
                    Count: 0
                    Count: 62976
                    Count: 0
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 207
                    Mileage: 193912 km
                    Time Indication: 0
                    Date: 2015.02.06
                    Time: 15:09:10
             Freeze Frame:
                    Count: 1088
                    Count: 0
                    Count: 4608
                    Count: 65
                    Count: 50210
                    Count: 257
                    Count: 65024
                    Count: 0
             Freeze Frame:
                    Fault Status: 00101100
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 207
                    Mileage: 193912 km
                    Time Indication: 0
                    Date: 2015.02.06
                    Time: 15:09:19
             Freeze Frame:
                    Count: 67
                    Count: 0
                    Count: 4608
                    Count: 64
                    Count: 50470
                    Count: 252
                    Count: 64512
                    Count: 0
Not time for a new sensor. "Electrical Fault in Circuit" is the clue.
The wiring harness will be damaged. It runs from the sensor in the hub to the ABS multiblock.
Thanks. I've got it in for MOT today so I'll ask them to try and sort it.
Update: Garage advised that they'll want to change the sensor first then monitor.
MOT has passed.
