Fabia 1.6tdi eml lit p0113
Hi I’ve had the car into the garage and it’s been diagnosed with the fault P0113. The relevant sensor was changed but the fault is still there. I’ve checked continuity from the sensor wiring to the connector by the gearbox and all checks correct. I’ve taken the air filter housing battery and tray out and the wiring appears ok. Is there a fuse and if so where would I find it please? Many thanks
I had a similar fault. Read this: https://www.briskoda.net/forums/topic/453799-skoda-7308-air-intake-temp-fault/
Eventually traced to G42 air intake sensor on the car. It sits low down behind the front grill, driver's side (hidden by the engine tray). Subject to vibration, chaffed wiring.
Thanks for your input Spartacus 68. I had the car checked by a person who I trust 100 %. He replaced the sensor at my request but the fault was still there. We deduced there was a break in the wiring harness. I checked continuity of the harness wiring from the sensor plug to the connector by the gearbox and all was fine. It went to an auto electrician who found a break in the wiring by the ecu. I removed the battery, battery tray, air filter assembly to gain access to the area myself and the wiring appeared perfect. As you know you can’t remove the connectors from the ecu without the proper equipment, which I don’t have. Altogether the repair cost me £145 including the sensor so not too bad. Thanks once again 👍
