Parktronic button wiring map plz!
Hi guys,
I am almost done installing front OPS to my octavia FL. I connected the parktronic button to the control module, but I dunno where to connect the illumination line and the two grounds of the button.
I also wonder where to hock the buzzer?
Thanks!
21 minutes ago, AkisVH said:
I actually don't know how to connect those three wires of the button to the ESP switch. Any ideas?
You can g have  the 2 grounds and illumination connected to ESP switch which is easy near it and should be same colored accordingly , and the rest 2 to the  T16 connector CAN  as the numbered pins 1to13 and 6to4.
Thanks for the details, but I still can't understand the ESP switch part. So, you want me to cut and merge those three wires (2 grounds and illumination) to the parallel wires of ESP switch or what?
Yes there are some special joints for cables  to do so you can search in local market for parts so that  to merge cables  easier and thus do more professional work.
Alright, I did the connections. The switch lights up and works fine.
Thank you!
Edited by OsamaAtallah
