electrical ground
hello everyone, new member here, can anyone tell me why my chassis voltage is sitting at 12 volts , vehicle stats and drives fine but  rear lights going haywire like with an earth fault .
Measure the voltage between the battery negative post and the chassis, that will tell you whether you have a bad earth or not.Should be as close to zero as possible.
voltage is showing as about 12 volts , however I now believe this not to be the problem as i have festooned the car with additional earth wires to battery -ve and things revert to normal . I believe the voltage reading to be a floating voltage which did cause me much anguish. I now have to go round the earth points with copper grease , do you know where actual earth points for the rear lights is located?? thank you maccy this has been a good first visit for me.
Don't use copper grease, it doesn't conduct well.
Most  modern DVM( meters) are very high impedance (i.e. they do not load the circuit )and will show the  no load  voltage( try putting a meter on the earth point showing 12v and then connect a load e.g. a brake lamp across the meter and i'd suggest voltage will drop) .  If ( with all the additional earths removed) and all rear lights switched off you get zero volts between chassis & the other point, try eliminating the circuit by looking for the light circuit which gives you a reading when operated. e.g. sidelights =no volts, but brake lights =a reading circa 12v, then it's most likely the earth for the brakelights ( most common suspect as they draw the most current and hence a greater voltage drop across any potential high resistance. )
Might be easiest to find the circuit that produces a voltage and run a wire from the earthy side of the circuit to chassis.
Edited by VWD
thank you , sepulchrave , i will heed your advice re coppergrease . hello vwd  thank you also i am going to follow your suggestion using a conductor from the chassis to the brown connectors on the light clusters
