Differences between Monte Carlo and standard Outdoor Yeti
Cosmetic differences aside, does anyone know if the Monte Carlo Yeti (2015 on) is fitted with lower or stiffer suspension, bigger brakes etc etc?  Also any differences between 2WD and 4WD versions. The diesel versions are obv a bit heavier, did they make any adjustments to suspension to take account of that I wonder?
As far as I remember the differences were purely cosmetic.
There are obviously mechanical differences between engine sizes and 2wd and 4wd when comparing anything in the Yeti range
But Monte Carlo is purely a trim level so a 2.0TDi 4x4 will be Mechanically the same whether it's a monty or SE or SE-L etc.
What changes is the amount of equipment and the trim etc.
