VCDS help
Long time lurker on here looking for some help as I've made a mistake (I think).
I was having a faff with VCDS tonight and enabled a couple of things ontop of what I had already done. Some worked some didn't. Those that didn't work I reversed. However, I'm now getting a lot more options in the light settings menu in the infotainment system that I don't recall enabling.
The options are as follows:
Dynamic Light assist
Light Assist
Dynamic Cornering Light
Switch on time
Automatic headlight control in rain
Travel Mode
Front background lighting
Roof background lighting
Door background lighting
Footwell lighting
Coming home function
Leaving home function
Obviously it would be great if a 2016 Fabia Monte Carlo has these options but it doesn't. All of the extra options return a "function not available" error when selected and the cars behaviour seems to be the same. The car doesn't have a Rain Light Sensor installed and doesn't have auto lights and definatley no ambient lighting.
I comapred the coding of the modules using an autoscan that I had saved the day before before and the module coding for module 09, 17 and 5F is the same.
Its as if I've checked something to say an extra sensor(s) have been installed.
How do I remove these options from the menu?
Autoscan from before
Friday,18,September,2020,16:14:07:03001
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
VIN: TMBFN6NJ3GZ16   License Plate:
Mileage: 55894km-34730mi   Repair Order:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: TMBFN6NJ3GZ16   Mileage: 55894km-34730miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CJZD)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H23 9086
   Revision: R4H23---
   Coding: 01190032230415080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001009
   ROD: EV_ECM12TFS01104E906027BC.rod
   VCID: 6695B188D8E776ABC8F-8032
   CAN Converter 01:
No fault code found.
Readiness: 1110 0001
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08504677160306
   Coding: 43F5487D492933C5091810720057C21292CC9008000DCAF98F00
   Shop #: WSC 13765 031 12345
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 372B2CCCCFCD3F23A39-8062
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 A    HW: 6V0 820 045 A
   Component: AC Manuell    H01 0202
   Serial number:  1602081B-0460
   Coding: 100000001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_SK26.rod
   VCID: 303917D02AA3E81BE23-8064
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0087
   Serial number: 006098053637
   Coding: 0F0008404205005B03A04080B10703080000D800D6013500000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   Sensor For Anti Theft Alarm System:
   Subsystem 1 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY160131WNT
   Alarm horn:
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064866044
Address 10: Park/Steer Assist (J446)       Labels:| 5Q0-919-283.clb
   Part No SW: 5Q0 919 283 F    HW: 5Q0 919 283
   Component: PARKHILFE 3K  H10 0054
   Revision: --------    Serial number: 39291607101847
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14AU3700000 002024
   ROD: EV_EPHVA14AU3700000_SK26.rod
   VCID: 3C2133E0F6EB1C7B4EB-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 05111504391520
   Coding: 00000000FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   ROD: EV_ACCMRRBoschVW372_VW26.rod
   VCID: 3A2D35F8FCDF224B5C7-806E
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag74D 002 0380
   Revision: --------    Serial number: 003TJ002JPS$
   Coding: 88CCC000000000005C5400CF008800000000
   ASAM Dataset: EV_AirbaVW20BPAVW26X 001001
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B2330FCF3E51B43471-806E
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 410 820 803 16
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00B91FF74B0225X
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 410 820 803 16
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00BB1FED6D0E119
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 442 151 403 16
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C11FACC83D36-
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 442 151 403 16
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00B71E52A571206
   Coding: 2D2D2D
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 6V0 920 946 A    HW: 6V0 920 946 A
   Component: KOMBI         205 1420
   Coding: 272D01002180A60001883A011000000000000000
   Shop #: WSC 73430 031 12345
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0087
   Revision: --------    Serial number: 006098053637
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   VCID: 6597B68425E17DB3C15-8030
   Multi Function Steering Wheel Control Module:
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000D0543090316
   Battery Monitoring Control Module:
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 63067N19402821695788
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C2 909 144 AG    HW: 6C2 909 144 D
   Component: EPS_TRW_ALow  322 3232
   Serial number: CG3E0789
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6E85C9A8F017BEEBB0F-803A
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-STD2.clb
   Part No SW: 5Q0 035 842 A    HW: 5Q0 035 842 A
   Component: MU-S-D-ER     H25 0245
   Serial number: SKZAZ2S5018088
   Coding: 03620000BE00000011111204008808002F0107C60120010000
   ASAM Dataset: EV_MUStd4CTSAT 001022
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 2D070EA43D9185F3C95-8078
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 6V0 919 604     HW: 6V0 919 604
   Component: ABTm_Std2  H41 1031
   Serial number: SKZ8Z9SLB003QL
End----------(Elapsed Time: 00:40, VBatt start/end: 13.5V/13.5V)-----------
Autoscan from after
Saturday,19,September,2020,21:48:11:03001
www.Ross-Tech.com
Mileage: 55937km-34757mi   Repair Order:
VIN: TMBFN6NJ3GZ16   Mileage: 55937km-34757miles
   Revision: R4H23---
   CAN Converter 01:
Readiness: 0000 0000
   Alarm horn:
   Coding: 0001050001
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 2D2D2D
   Coding: 273D01002180A60001883A011000000000000000
   Coding: 000700
End----------(Elapsed Time: 00:40, VBatt start/end: 14.3V/14.3V)-----------
Autoscans were supposed to be collapsed and scrollable not take up pages worth of space my mistake.
This issue seems to have fixed itself. After coming back to the car after an hour and plugging back in the options have gone. Does anyone have any idea why this is?
I also found the debug folder which lists all changes made using the cable and as many weren't made it was easy to find the original coding for the modules but that is obviously not needed but they have now been written down so I can revert to factory if needed.
